Nářadí Tenere
Nářadí Tenere
Prosimvás, byl by někdo ochotný sem nahodit foto s popisem nářadí, které se cpe mezi nádrž a sedlo u Tenerky? Sem to koupil bez toho a chtěl bych si nějaký nářadí stvořit. Děkuji předem.
Re: Nářadí Tenere
Podobne, som rovnaký prípad.... Bodlo by to.
Trochu iné poňatie asi TAKMER KOMPLETNÉHO náradia: je to zoznam z iného /EN/fora, čo na Teneru treba, rovnako aj nejaké skruty pre prípad nutnosti.
This is all for a Tenere, so you might want to check some of the sizes, but I would have thought the bulk of it would be the same.
Main sizes are:
Rear Axle: 22mm socket or spanner
Chain adjusters: 10mm and 12mm open-ended spanners
Front Axle: 14mm hex key
Front Axle Pinch Bolts: 6mm Hex/Allen Key
Most of the bodywork: 4mm allen key
Airbox/filter: Fairly big Phillips screwdriver.
Spark plug: 16mm (I think)
6, 8, 10, and 12mm sockets, and a 5mm allen key will do pretty much everything else on the bike.
My kit is as follows (as far as I can remember, may edit later). It doesn't fit under the seat, but it does all fit in a Kriega US-5. The Motion Pro gear is horribly expensive, but it does really cut down the amount of stuff you need.
Wheels and Tyres:
Motion Pro tyre-lever/spanners (22 and 27mm)
3/8" drive adapter for the 27mm lever.
(14mm 3/8" drive key for the front axle - I've ditched this now because I don't have standard forks any more - the 27mm spannerlever does mine now)
Hand pump
Pressure gauge
Spare front tube
Valve core extractor
Tyre patches, glue, etc.
General tools:
Motion Pro trail tool
Gerber Suspension multitool
3/8" extension bar
A few odd bits and pieces the MP trail tool doesn't have, like a 4mm allen key for the bodywork, and 10/12mm open-ended spanners for the chain adjusters.
LED Headtorch
General spares:
Fuses
Number plate screws
Screen screws
Zip-ties
Probably a few other bits I've forgotten
And a towrope!
Screw Kit Contains:
8mm flange bolts-
2x M6 40mm
4x M6 25mm
6x M6 20mm
6x M6 16mm
6x M6 12mm
Screws-
4x M5 10mm pan head
10mm flange bolts-
2x M8 40mm
2x M8 30mm
2x M8 16mm
Washers-
6x M6 Flat
4x M8 Flat
6x M6 fender
4x M8 Fender
/Origo bez úpravy/.
Main sizes are:
Wheels and Tyres:
Hand pump
Pressure gauge
Spare front tube
General tools:
3/8" extension bar
LED Headtorch
General spares:
Fuses
Number plate screws
Screen screws
Zip-ties
And a towrope!
Screw Kit Contains:
8mm flange bolts-
2x M6 40mm
4x M6 25mm
6x M6 20mm
6x M6 16mm
6x M6 12mm
Screws-
4x M5 10mm pan head
10mm flange bolts-
2x M8 40mm
2x M8 30mm
2x M8 16mm
Washers-
6x M6 Flat
4x M8 Flat
6x M6 fender
4x M8 Fender
/Origo bez úpravy/.
Naposledy upravil(a) MaxoT660 dne úte 10. dub 2012 18:30:31, celkem upraveno 1 x.
Život je len jeden ....
Re: Nářadí Tenere
To vypadá na veškerý nářadí na každičkej šroubek, to pod sedlo nenacpem.
- Carlos Checa
Re: Nářadí Tenere
Večer ti to nafotim
Re: Nářadí Tenere
Ok budeš laskav
- Carlos Checa
Re: Nářadí Tenere
To je nějaké slabé. Originál nářadí u XTR bylo bohatší. ale třeba inbus klíč na osu předního kola tam taky nebyl. Na fotce nevidím ani klíč na povolení osy zadního kola. A když chytneš defekt, tak vůbec nemáš čím - montpáky na přezutí...
- Carlos Checa
Re: Nářadí Tenere
Dotaz byl na origo nářadí!!Je pravda,že tim nesundáš ani jedno kolo
Re: Nářadí Tenere
Tak klíče sou jasný, 10,12, pak imbus to teda nevim kterej, 5,10? Trubka je z obou stran svíčák? tedy 16? Šroubováky to je jasný, ten plochej bazmek kterymu nevím jak se říká odborně je na zadní tlumič co? No a ta trubka na jedne straně sešláplá to teda bych taky potřeboval nápovědu pokud by to šlo. Vím že su votravnej ale dík.
Re: Nářadí Tenere
Ta "na jedné straně sešláplá trubka" je nástavec, který se dá použít libovolně, aby sis např. zvětšil páku. Primárně je určená jako nástavec k tomu klíči na zadní tlumič.
Re: Nářadí Tenere
Čau, ...já měl v originále ještě klíč na zadní kolo.alsonztvargla píše:Prosimvás, byl by někdo ochotný sem nahodit foto s popisem nářadí, které se cpe mezi nádrž a sedlo u Tenerky? Sem to koupil bez toho a chtěl bych si nějaký nářadí stvořit. Děkuji předem.
Podstatné ale je, že originální nářadí od výrobce je nedostatečné a po jeho doplnění nikam do motorky (bez úprav) nevejde.
Uživatelé prohlížející si toto fórum: Žádní registrovaní uživatelé a 57 hostů
