TPS
Re: TPS
Co takhle hledat zde na foru ? navrhuji zadat TPS do policka pro vyhledavani ....
a vysledek :
viewtopic.php?f=13&t=1722#p29809
a vysledek :
XT 660 R, r.v. 2004 cerna
Re: TPS
Pres palubni pocitac se muzes podivat jake hodnoty TPS vraci... postup z XT660.com:
Jeste bych k tomu doplnil, ze kdyz uz ti tam sviti to cislo, ktere z toho senzoru leze, tak zkus otacet plynem, melo by se zvysovat a mam pocit, ze pri plnem plynu bys mel videt hodnotu 99, ale uz si tim nejsem jistyDISCLAIMER: YOU DO THIS AT YOUR OWN RISK AND MAY VOID THE MANUFACTURERS WARRANTY.
Throttle Sensor Adjustment:
To do this modification you need to put the bike in diag mode:
To access DIAG mode:
switch off Engine Run switch, switch OFF Key switch. Press both SELECT & RESET buttons and then switch ON Key switch. Keep SELECT & RESET buttons pressed for at least 8 seconds. Display then changes to "DIAG". Release SELECT & RESET buttons.
Select Diag mode by pressing again both SELECT & RESET buttons.
Select code below by pressing SELECT (up) or RESET (down).
On the digital display select 01 (throttle position) and make a note of the number on the screen. It should be between 16 - 18.
Now locate the throttle sensor, its on the right hand side of the bike behind the cylinder.
Slacken the two bolts indicated in the above photo. Using a T25 Torx.
If you rotate the sensor clockwise/ anti clockwise you will see the number of the digital display increase and decrease.
Set the value to between 15 & 18.
